    Herb Miles's Avatar
    Herb Miles Guest
    Question Trane Heat Pump - Need Help Verifying Ton Rating
    I have a Trane model 4twr5048e1000ab heat pump. From what I can find this is a 4 ton unit. Can anyone verify?
    Thanks...
    Default Re: Trane Heat Pump - Need Help Verifying Ton Rating
    Quote Originally Posted by Herb Miles View Post
    Thanks...
    That's the way I see it.
    Herb Miles's Avatar
    Herb Miles Guest
    Smile Re: Trane Heat Pump - Need Help Verifying Ton Rating
    Thanks, Billy - does the leading 4 in the model number indicate it was manufactured in 2004?
    Garland, TX
    Herb,
    The Model # has the Size information,
    The Serial # will have The Manufacture Date in it.
    *see Barry's Link to match Serial # to dates of manufacture.
    Herb Miles's Avatar
    Herb Miles Guest
    Thumbs up Re: Trane Heat Pump - Need Help Verifying Ton Rating
    Thanks to both of you! Think I have it figured out.
