Thread: AC Outlet
07-17-2012, 05:04 PM #1
AC Outlet
Under the wall AC unit in our new home, there's an odd outlet:
We'd like to install a new AC. Can I get an adapter for this or will I need an electrician to install a new outlet?
Thanks!
07-18-2012, 08:59 AM #2
Re: AC Outlet
We can't answer that question from here. It may very well be a 240 volt receptacle specifically installed for an AC unit. 240 volts will destroy a 120 volt unit, so you need to have it tested to see what you have.
07-18-2012, 11:09 AM #3
Re: AC Outlet
What John said. If you Google up a receptacle configuration chart, it will probably indicate that as a 15 amp - 240 volt receptacle w/ ground wire. Like John said you must also check it with a volt meter because you are not the only one that might confuse the voltage. It should be just fine for the new unit, as long as the voltage and amperage is compatible. If the new unit cord cap is not compatible, I recommend a pro. Easy enough to change either the receptacle or new unit cord cap, but again all must be compatible to do so.
Last edited by Garry Blankenship; 07-18-2012 at 11:11 AM. Reason: typed cop ~ meant cord
07-18-2012, 09:21 PM #4
