Results 1 to 11 of 11
		Thread: Bathroom fan ducting question
	08-06-2012, 11:20 AM #1
		Hey all.
I'm looking at putting a bathroom fan into a 50's era, single-story house that currently doesn't have one. The options appear to be vent to the roof, or vent through the gable. Being concerned with introducing a leak in the roof, I'm leaning toward the gable vent.
1) Do I actually have the choice of where to vent? (i.e. if it's the attic and not between floors, am I required to vent to the roof)
2) If I vent through the gable, am I allowed to run the duct over the joists, or do I need frame something in around the ductwork?
thank you!
chris
	08-06-2012, 12:12 PM #2
 Re: Bathroom fan ducting question
	08-06-2012, 12:52 PM #3
		Ideally the duct will be galvanized sheet metal and not flexible aluminum or vinyl. It must terminate at a dampered hood at the roof, side wall, or soffit. The shorter the duct run the better it will work. Reference the fan manufacturer's installation instructions, IRC 102.4 and 303.3, if applicable in your area.
Texas Inspector
http://www.texasinspector.com
	08-06-2012, 02:31 PM #4
		Number 3, don't use that cheap plastic duct tape (duck tape) that melts in the heat and allows the pipe to fall back into the attic. Use metal foil tape or screw and clamp everything.
	08-06-2012, 06:22 PM #5
	08-09-2012, 03:57 AM #6
		Texas Inspector
	08-09-2012, 07:05 AM #7
		I can't recall ever seeing a solid metal vent pipe used for a bathroom vent. Not saying it is a bad idea, I just can't recall ever seeing it done. All I see are flex vinyl, flex alum foil vents or Mylar type vent pipes.
	08-09-2012, 07:17 AM #8
	08-09-2012, 08:03 AM #9
		The flexible vinyl ducts trap dust and go moldy. I'll post some pics.
Here's a pipe full of crud that blew off as well. Actually, it looks like somebody covered the fan purposely. Whatever.
	08-09-2012, 08:40 AM #10
		Texas Inspector
	08-10-2012, 10:57 AM #11
		Thank you all so much for your input. I really appreciate it!
Chris
