Results 1 to 11 of 11
08-22-2012, 02:53 PM #1
Bathroom Entry Door - Min Opening
Lets say my current bathroom door when closed is at 0 degrees. At present it can open to a max of approx 120 degrees before it it hits the shower bath pan. Is this an acceptable door opening criteria? What is the minimum a bathroom door can opened before it violates some code? 90 degree's? Thank You
08-22-2012, 03:01 PM #2
08-22-2012, 04:10 PM #3
Re: Bathroom Entry Door - Min Opening
08-22-2012, 06:11 PM #4
08-22-2012, 06:28 PM #5
Hi Vin and Welcome,
Just curious as to why this would be an issue ?
If hitting the shower pan after 120 degree swing bothers you you could install a hing door stop Hinge Pin Door Stops - The Hardware Hut
08-23-2012, 05:43 AM #6
08-23-2012, 06:12 AM #7
Vin.
If the bath was original construction and it received an occupancy permit then it fine to your local code.
A door moving past 90 deg does not increase access in general.
If the door met the interior wall instead of a shower bath pan would it make a difference? No.
08-24-2012, 06:42 AM #8
08-24-2012, 07:01 AM #9
08-24-2012, 07:39 AM #10
Jerry
Tubs (like people) can come in a variety of sizes.
I have seen several 5x7 garden tubs.
08-24-2012, 08:32 AM #11
