Results 1 to 2 of 2
    Fred Willis's Avatar
    Fred Willis Guest
    Default Installing Bathtub in place of shower -Slab
    I would like to remove a shower stall and install a bathtub in its place in my basement bathroom. The drain is set in concrete . Instead of breaking up the concrete I want to raise the tub up on a mini-platform in order to run the tub drain to the existing drain in the concrete. Is this something that can be done without violating any codes? appreciate any insight. Thx
    Inspection Referral SOC
    Default Re: Installing Bathtub in place of shower -Slab
    Quote Originally Posted by Fred Willis View Post
    Is it possible, yes.
    Do you have the experience, knowledge and skills, I (we) don't know.
