Thread: Cracks on the roofing board
10-22-2012, 10:32 AM #1
I have noticed multiple cracking lines on my roofing board (attached photos). There is no leaking or anything wrong so far, but I am wondering if the broken board can bear the snow weight as normal, or if it is prone to causing subsequent damage of the shingle and tarpaper above?
Moreover, if I am going to sell the house, would it be something that inspectors can pick on?
Thanks!
Similar Threads:Last edited by Hans Liu; 10-22-2012 at 11:43 AM.
10-22-2012, 10:56 AM #2
Re: Cracks on the roofing board
It is unlikely to ever cause a problem.
Most likely it was caused by the roofer shooting nails into that big oversized knot in the plank. If there is no sign of a depression on the outside, and you have good quality shingles on your roof, snow will not cause a problem, in my opinion.
10-22-2012, 12:42 PM #3
Hater to disagree with you John.
There is a good potential that snow over time there will be an issue with snow/ice on that section of board.
The bigger issue may be when someone walks over the broken board and cracks the shingle.
The fix is easy. Needs to be braced/spliced across the break.
10-22-2012, 03:53 PM #4
10-24-2012, 04:31 AM #5
Thank you all for your opinions! That is very helpful.
10-24-2012, 08:10 AM #6
Just curious, is this a new roof? The lumber looks new in the photo, and haven’t seen boards used, in forever. I had the same issue on my house when I bought it and it was never a problem. I just added a 2x to bridge the span so I would not have a soft spot, and just replaced that board when I re-roofed.
