Results 1 to 12 of 12
Thread: Type B Vents
11-27-2012, 07:34 PM #1
Type B Vents
Type B vents are double walled to help the flue gases move forward in the unconditioned spaces. Now if I have a single walled vents through out the chain, then do I have to buy a whole new type B apparatus or I can just wrap a sheet metal jackets on the current venting and have the double walled feature of Type B vents. Would save me much cost and also a lot of time.
The vent system goes from 80% Eff. 60K BTU natural gas furnace in the basement and goes vertical after 5 feet passing through attic and then out the roof.
Also, if I have to do the Type B stuff then can it be replaced by PVC deals at 5". Would save immense amount of time although might cost much more.
11-27-2012, 07:48 PM #2
Re: Type B Vents
Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
11-27-2012, 07:53 PM #3
Re: Type B Vents
What is SW, can't figure this out. Would using 5" diameter PVC help.
11-27-2012, 08:01 PM #4
Re: Type B Vents
11-27-2012, 08:23 PM #5
Re: Type B Vents
You say can't have SW through an attic. Fine. I was presuming that it is SW through out. I will have to get to various levels to make sure of what type venting it is. I had the home inspected before buying 7 years ago. Would the inspector have checked this out that there is a Type B in the attic atleast. Also, the previous furnace was some 30 year old Anthes 60K BTU brand. Were the real old furnaces ok with the SW or they required Type B also.
Also, would covering SW by pink insulation throughout help any and more so because...........
The insulating materials in PINKĀ® fiberglass insulation are noncombustible. Its natural fire resistance is unaffected by moisture, evaporation, or time, which makes Owens Corning insulation a very reliable product.
11-27-2012, 08:34 PM #6
Re: Type B Vents
Its not the furnace that is of issue its the vent type and the vent clearances that is of issue. Even if "IF" SW was allowed to be run through an attic, now its not. At some point in time, a fire or fires resulted, or even death or multiple deaths. Its sort of how code and law come about. Its all about safety. Personally, as an HI, my #1 concern is my clients health and well being.
10.1.6.3
Single-wall metal pipe shall be used only for runs
directly from the space in which the appliance is located,
through the roof or exterior wall to the outer air.
10.1.6.4
Single-wall metal pipe shall not originate in any unoccupied
attic or concealed space and shall not pass through
any attic, inside wall, concealed space, floor, or ceiling.
11-28-2012, 08:32 AM #7
Re: Type B Vents
You say the furnace is in the BASEMENT and that there is an ATTIC: This implies at least one "floor" or story, if not two, of occupied space between same. You say the "furnace" is 80%, you don't say if natural draft. Not "sold" on the "idea" that B-vent is necessarily the correct venting system in the first place, in NO case can you do ANY of the "deals" "stuff" or DIY "stuff" you suggest, and do so safely. If/when someone is hurt, dies, you would be responsible. From what you have stated, YOU should NOT be doing ANYTHING EXCEPT HIRING A Licensed PROFESSIONAL to evaluate and perform the work, and doing so IMMEDIATELY. B-VENTing SYSTEMs must be enclosed (with sufficient SPACE clearance within), behind stopped walls on all occupied floors. It must be sufficiently supported, fire stopped and blocked where it passes through floor/ceiling ssemblies, at least every 10' vertical, at any change in direction, and within the CHASE between the equipment in the bsement and origination of the B-Vent system (well below the ceiling assembly in the bsement) and through the occupied space. Your Attic is apparently occupied (used for storage, or whatever) so a chase there is likewise needed, you may insulate the CHASE wall, beyond the inner gyp wall liner, NOT the B-VENT. YOU MAY NOT ENCASE the vent with PVC or sheet metal or insulation. All trap and hold/reflect HEAT. A 1" minimum AIR SPACE clearance is required for b-vent trade size 12" or less.
YES it has to be purchased as a listed system and componants thereof, it MAY NOT BE "field fabricated". I do NOT suggest YOU buy anything. Hire a Licensed trained professional to determine the correct trade size, draft (min & max), length, effective length, and to fully specify, configure, and install.
Also, if I have to do the Type B stuffthen can it be replaced by PVC deals at 5".
Would save immense amount of time although might cost much more.[/quote]
What is SW, can't figure this out.Would using 5" diameter PVC help.
I had the home inspected before buying 7 years ago.Would the inspector have checked this out that there is a Type B in the attic atleast.Also, the previous furnace was some 30 year old Anthes 60K BTU brand.
Get a licensed PROFESSIONAL.
11-28-2012, 09:03 AM #8
Re: Type B Vents
Ditto H. G.
There are many thing in a home that DIYer can do, but based on your questions, you absolutely need a professional. We constantly see where smart guys thought they had figured out a common sense "fix", but they end up just figuratively putting lipstick on an alligator, and still have a beast of a problem.
Fork out the dough, and pay a pro to fix your vent.
11-28-2012, 02:35 PM #9
Re: Type B Vents
Just checked today and went to the attic also. It is a type B vent all the way. It starts from the end of 3-4 feet of horizontal connection from furnace, ofcourse after 18 inches of rise from 4" furnace exhaust vent, the Type B goes all the vertical to the roof and then ends with a Thimbled cap. I would need a Type B connection for the 3-4 feet horizontal run from the furnace. Yes the furnace is Cat 1 fan assisted combustion on the natural gas.
11-28-2012, 02:38 PM #10
11-28-2012, 02:46 PM #11
11-28-2012, 03:24 PM #12
