    Matt Barenbrugge's Avatar
    Matt Barenbrugge Guest
    Default furnace/water heater venting together
    I am working on a house where the furnace and hotwater heater are on the same vent. The vent from furnace and water heater are three inch. then they "Y" to a 6-7" double wall which makes sense to go through the floor and roof. Now here is where I am stumped. Above the floor behind a bathroom vanity the double wall reduces to four" then back to 6-7" before going through the attic. Is this OK?
    Default Re: furnace/water heater venting together
    No, not from what I envision.
    Aug 2011
    The short answer is no.
    Chicago IL
    NO
    Also the original connection may or may not be proper depending on whether the furnace is power vented or not.
    www.aic-chicago.com
