    Feb 2013
    texas
    Default AC ducts run on the exterior of new home
    Quick question for the group,
    I’m building my first and last house, and the builder and the AC tech ran two ac lines through the trusses for the back pouch and then up 2 foot or so along the exterior of the house, before reentering the house.
    We have a 12” load bearing truss/beam that supports the upstairs that they do not want to cut, so they ran the AC lines the way they did.
    One AC line is a return and the other feeds the master bedroom and bath. The home is located in hot climate, South Texas.
    Does this present an issue for cooling? Will this be an issue when I sell the home in 10 -15 years? Is this an expectable building practice? Would you gig this? Of course the builder is saying they do this all the time, and I’m not a builder.
    Bothe AC lines are insulated, and the chase on the outside of the house will be wrapped with moister barrier and then stucco’ed.
    Please see attached pics.
    Thank you in advance for any and all comments.
    Fishman
    Default Re: AC ducts run on the exterior of new home
    Quote Originally Posted by Fishman View Post
    Fishman
    You stated these will be enclosed , I don't see an issue.
    I would make sure they bring the ducts into the thermal envelope by installing insulation in the chase walls and fire stop the top and bottom of the chase.
    Aug 2009
    rockport texas
    i don't think you'll have a problem. You are however going to have a problem with the bottom of the columns for the front porch.
    Feb 2013
    texas
    Default Thank you
    Billy, Jim, and Stanly,
    Thank you all for your responses.
    I went by the house this AM and the back porch roof system is part of the building envelope and can be access from the attic space above the master bedroom.
    So as far as the outside chase above the porch roof goes, I will ensure it is well insolated and fire proofed by the builder.
    Thank you again, Fishman
    Default Re: Thank you
    Jim, fire proofed by the builder.
    Fishman
    Mr. Luttrall's point was " fire stop."
