Results 1 to 9 of 9
    Feb 2010
    Irvine, California
    Default No venting hood above electric cooktop
    An old condominium, the seller installed new electric cook top on kitchen island but NO Hood above it.
    my client said the kitchen hood is mandatory on transaction of house like smog detectors.
    Is it true in california?
    Default Re: No venting hood above electric cooktop
    Your Client is Wrong.
    * if your client wants an exhaust then negotiate the cost of one off the asking price.
    Quote Originally Posted by Ben Im View Post
    Hoods not required with cooktops, stoves, etc... They are nice but not required....
    Smog detector? Really?
    Yep,
    Nobody likes some ole lingering stale smog hanging around.
    Feb 2010
    Irvine, California
    Red face Re: No venting hood above electric cooktop
    OMG, I did type "smog"
    Embarrassing,,,
    Nov 2009
    St Paul, MN
    Unless they have a grill feature, then they are required.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Not just a grille feature either, but an open top broiler - basically think of your outdoor BBQ being indoors with no hood to cover it ... then think of when it flames up and you have fire 3 feet high ... Yikes!
    Not only does that require a hood, but it also requires additional clearance to combustible material above and to each side.
    Electric cooktop = no problem.
    Western Montana
    I am certainly not Jerry Peck, but in my reading of building codes I can only find standards as to how a vent should be installed (also see manufacturer). I sometimes do write up cases when a hood does not have adequate clearance. etc. But, I can NOT find any code that says a vent or hood is required to be installed. But, the buyer can always ask for what they want, just can't claim it is required by code.
    Manufacturers of cooktops with grills have specific installation instructions in regard to clearance to combustibles (cabinets) and venting. The code requires the cooktop to be installed to the manufactures instructions, these instructions are different from standard cooktops. So the requirement for clearance to combustibles and/or need for a vent hood are determined by the manufacturer.
