Thread: Sump pump crock and shelves
03-16-2015, 06:58 AM #1
Would like to place a shelf approximately 2 to 3 feet above the sump pump crock. Its a submersible sump pump and the plumbing exits through the wall just below the 2 feet mark. As long as the pump is accessible does code prohibit having anything above the pump?
Vic Lepouce
03-16-2015, 01:23 PM #2
Re: Sump pump crock and shelves
Nothing that I can think of.
03-21-2015, 06:56 PM #3
The mechanical code requires clearance for servicing and access. As long as you maintain those required clearances it will be fine. That clearance would include the removal without taking anything down or apart.
PROFESSIONAL CONSULTING AND INSPECTION COMPANY INCLUDING FORENSIC INVESTIGATIONS
http://jeffghooper.com/
04-13-2015, 10:44 AM #4
