    Apr 2016
    Arizona
    Default can you splice two hard pipe gas lines using a flex line?
    under manufactured home where the two sides of the house were joined together, are hard pipe gas lines that did not line up, so they joined the two pipes together using flex line.
    Is this to code/legal? is this common? this is in Arizona.
    I am having trouble uploading pictures.
    Default Re: can you splice two hard pipe gas lines using a flex line?
    I can't be sure whether that connection is permitted by the gas safety authority for your area, or if you even have such a thing. But the usual building code rules probably do not apply.
    If it is permitted by the manufacturer of the home, then that is usually the standard that will be applied, AFAIK. You could ask the building official in your town if the local building code applies to your manufactured home, and specify that it is a gas installation you are concerned about.
    Then you could ask the installers to change the connection to hard pipe. Maybe you smelled gas in the crawlspace?
    Dec 2007
    Osceola, AR
    Quote Originally Posted by Brian Phelps View Post
    I would have an issue with using an appliance connector in the application, CSST would most likely be OK. All up to the Authority Having Jurisdiction (local code or building official). Attached is an illustration from another inspector (Rueben Saltzman at StructureTech) showing CSST line and a flex appliance connector.
    Alton Darty
    ATN Services, LLC
    www.arinspections.com
    Really common with manufactured/mobile homes. Since the two halves are two units that are connected together, any electrical, gas or plumbing connection needs to be able to flex, at least a bit. In addition, when they marry the two halves together, they need to have a method to connect the gas piping together. Specific information would require contacting the manufacturer.
    Sep 2010
    NY Finger Lakes Area
    .......all the above comments are correct. The only thing to check, is to determine if the connector was, in fact, the one supplied by the home manufacturer........Greg
    Hopefully (but unlikely, unless the manufactured home was new) the manufacturer's installation and setup guide is there. Those installation and setup guides specify everything about the installation and setup of the manufactured homes.
    Building codes only address from the connection points (gas, electrical, plumbing, etc) from the manufactured home outward to the site utilities.
    Oct 2011
    california
    Skyline Corporation manfu Home Installation Manual addresses gas connections between modular units with gas cross over connections using quick disconnect fittings or threaded connectors this is a flex between the marriage line of manfu homes
    Hope this helps answer is flex works if dome properly
