Thread: Eave Less
05-03-2009, 10:55 AM #1
Eave Less
Is there code for no eave over hang. A addition was added and the roof terminates at the exterior wall. Gutter is attached to wall and not serving any purpose due to rotted siding and roof sheating. This home is a weekend warrior mess. Inspection was supost to be yesterday but no power to home. Rescheduled for Tuesday so i am sure i will have more ?s
05-03-2009, 11:20 AM #2
Re: Eave Less
In Florida (which I acknowledge you are not) the code simply requires that when there is less than 6 inches overhang eave that, for termite protection, a gutter be installed and that the gutter discharge (any and all gutter discharge, which could be construed that no overflowing gutter discharge is allowed) must discharge at least 12" from the foundation, and, of course, the final grade is required to be sloped down and away from the foundation.
That does not help your condition in which the gutter has obviously allowed water to overflow back to the siding, rotting it out.
05-03-2009, 02:21 PM #3
Re: Eave Less
Ryan:
R319.1.3 Geographical areas.In geographical areas where
experience has demonstrated a specific need, approved naturally
durable or pressure-preservative-treated wood shall be used for
those portions of wood members that form the structural supports
of buildings, balconies, porches or similar permanent
building appurtenances when those members are exposed to the
weather without adequate protection from a roof, eave, overhang
or other covering that would prevent moisture or water
accumulation on the surface or at joints between members.
Depending on local experience, such members may include:
1. Horizontal members such as girders, joists and decking.
2. Vertical members such as posts, poles and columns.
3. Both horizontal and vertical members.
05-05-2009, 11:15 AM #4
Re: Eave Less
Ventilation of the attic space would be another potential problem area. Where does the air intake occur? Is it adequate?
Water should not get behind the gutter whether there is an overhang or not.Do shingles have enough projection past the drip edge and the back of the gutter?
Back to the original question. Besides ventilation is there another good reason for the eave overhang? It only protects the top two feet of the wall and results in uneven weathering and a two-tone house.
I think I will cut mine off when I reroof this summer. My overhang that is. My roof overhang!!!
05-05-2009, 04:10 PM #5
Re: Eave Less
Cape Cod style houses typically have no overhang at the eave. There is usually a fascia board (or molding) that is attached directly to the sheathing, and gutters (when provided) are attached to the fascia board. I live in one myself. It's 100+ years old and no problems with rot. The white cedar shingle siding is evenly weathered to the traditional Cape Cod silver-gray.
The lack of an overhang was originally intended to better withstand high nor'easter winds on the Cape. The lack of an overhang probably reduces the likelihood of ice dams, too.
Ventilation, when it's provided, is done with gable vents (more common on on older houses) and, on newer houses, with ridge vents and Hicks vents at the drip edge.
05-06-2009, 08:54 PM #6
05-06-2009, 10:06 PM #7
Re: Eave Less
Pics of eave less. Competly rotted out walls.
05-07-2009, 05:32 AM #8
Re: Eave Less
That is not because there is no overhang, that is because people do not understand how water flows and they do not use flashings, not not ship lap/shingle lap the material to shed water.
Stupid people do stupid things and, over time, those stupid things show the stupidity which was used.
