08-15-2009, 02:54 PM #1
Correct junction between masonry chimney and BUR
Does anyone have a diagram of the correct method of making this transition?
Thanks.
08-16-2009, 02:34 PM #2
Re: Correct junction between masonry chimney and BUR
I use the one at bottom of page
Copper.org: Architecture Design Handbook: Architectural Details: Flashings and Copings - Stepped and Chimney Flashings
may already be under all that deteriorated material
08-16-2009, 07:35 PM #3
08-16-2009, 08:02 PM #4
I think Barry has a good eye and he can see a chimney flashing under all that tar.
That roof/wall flashing on the lower left of pic1 is a piece of work too.
08-17-2009, 11:08 AM #5
the flashing membrane in the vertical plane should be terminated per BARRY ADAIR link or have a least a termination bar fastened properly to the brick where the flashing is installed.
