Results 1 to 14 of 14
		Thread: Wavy roof
	10-24-2009, 07:45 AM #1 Wavy roof Wavy roofWhat is likely to cause a wavy apppearance to a particular section of roof and what is the remedy?
	10-24-2009, 07:55 AM #2 Re: Wavy roof Re: Wavy roofStephen,
 There are a variety of potential answers. I have seen wavy roofs caused by rot damaged siding, improperly installed roof sheathing, improperly installed framing, etc. Without more information and maybe a picture or two, it really would be impossible to give you any kind of intelligent answer.
	10-24-2009, 01:47 PM #3 Re: Wavy roof Re: Wavy roofStephen, what did the framing and decking inside the attic look like? I often see sagging roof rafters that have been overspanned and sometimes plywood roof decking that has delaminated can result in a wavy appearance. If the roof had more than one layer of shingles, that could be a cause.
	10-25-2009, 02:35 PM #4
	10-25-2009, 03:54 PM #5 Re: Wavy roof
		"Baseball is like church. Many attend but few understand." Leo Durocher Re: Wavy roof
 Bruce Breedlove
 www.avaloninspection.com
	10-25-2009, 04:32 PM #6 Re: Wavy roof
		Department of Redundancy Department Re: Wavy roof
	10-25-2009, 05:15 PM #7 Re: Wavy roof Re: Wavy roofYeah, I am familiar with 'bird's mouth' but never heard the term 'crow' used with 'rafter'.
 Bruce Breedlove
	10-25-2009, 05:19 PM #8 Re: Wavy roof Re: Wavy roofBruce, I'm guessing that was a typo on Aaron's part and that he meant to type "crowning". However, if the work is bad enough, the correct term would be rafter "clowning".
	10-26-2009, 10:17 AM #9 Re: Wavy roof Re: Wavy roofWhile this does not typically show on the whole roof I have seen a lot of "waves" or uneven areas where the carpenters had to do a portion of the trussed roof framing by hand for a direction change.
 It seems that around here it is not a requirement to match the height of the hand stacked framing with the height of the adjacenent trusses. Because I see this alot. The most pronounced waves are found on the tile roofs where the tiles telegraph the defects much more so than shingles.
 I also see quite frequently that the roof rafters are not secured to hip trusses and after some time and some snow loading the hip trusses begin to lean backwards causing the roof at that area to sag.
	10-26-2009, 11:25 AM #10 Re: Wavy roof Re: Wavy roofI see this more on truss construction than with site built designs.
	10-26-2009, 11:57 AM #11 Re: Wavy roof Re: Wavy roofSome possible causes:
 Multiple layers of roofing.
 Not crowning (crowing) all of the rafters.
 Overspanned sheathing, or moisture issues in an attic causing sag in sheathing that is not technically over- spanned.
 Buckled or delaminated sheathing.
 Structural sag in the home.
 Loose sheathing that starts to pull up.
 Hmmmm. that's all I've got at the moment.
	10-26-2009, 12:11 PM #12 Re: Wavy roof Re: Wavy roof
	10-26-2009, 12:21 PM #13 Re: Wavy roof Re: Wavy roofApparently he wasn't really that interested.
	11-02-2009, 02:23 PM #14 Re: Wavy roof Re: Wavy roofWith older home I see allot of roofs having that issue, due to them being constructed with plank boards instead of sheathing…
