Results 1 to 14 of 14
Thread: Delaminated roof decking
03-25-2010, 06:54 PM #1
Why only some sections?
Solutions / Prevention?
Baffles were rectangular cardboard "tubes" about 3" X 5".
TIA
4 year old roof (2nd layer)
03-25-2010, 08:57 PM #2
Re: Delaminated roof decking
Looks like you have air sealing/ ventilation issues. I can't explain why it shows up only in patches though.
03-26-2010, 04:08 AM #3
What rooms were below the areas in question?
03-26-2010, 04:26 AM #4
Lack of attic ventilation. Insulation is preventing airflow. Are the soffits open, ridge vent ?
03-26-2010, 04:34 AM #5
03-26-2010, 04:42 AM #6
03-26-2010, 04:43 AM #7
03-26-2010, 04:45 AM #8
If the roof decking is currently wet, roof still leaks or those areas are over the bathrooms. If it is dry, it is probably previous moisture damage, most likely from the first layer of the roofing material. Is there a vapor barrier under the insulation? If there is no vapor barrier and you have poor ventilation, you will see the condensation in specific areas only, especially over the high moisture area. It condensates in the winter, absorbs into OSB when it melts. Delamination, mold is next
PRIME INSPECTIONS - home inspections services. Quality Home Inspections in Delaware County NY, Otsego County NY, Chenango County NY and surrounding areas. NY State Licensed Home Inspector lic.#16000041526
03-26-2010, 04:45 AM #9
03-26-2010, 05:03 AM #10
The why I say that is from personal experience (the bad kind). I did exactly that, architectural over 3-tab on low pitch. The thicker shingles have more tendency for water to wick-up at the bottom edge plus the triple thickness created at the top of the exposure causes a slight dip where water can almost puddle. The dip doesn't show up until a few years and is not every where. The leaks come at the nails next to the butt joints of the shingles. Might explain why yours jumps rafter bays if the shingles were racked.
What do I tell customers? Well they haven't been as dumb as me so far .
03-26-2010, 05:08 AM #11
you can see the insulation is tight up onto the roof, and i dont see any ridge vent panels to keep the insulation down, right now theirs no air flow
not sure of the proper name for those panels
03-26-2010, 08:32 AM #12
03-26-2010, 06:08 PM #13
It's definitely not the pitch, its at least a 5/12. I would guess a bathroom vent close to the problem area. The roof 2x4's show mold also. Definitely moisture is not being removed. Till the moisture problem can be determined I would recommend installing a small vent in the eave vent to keep the moist air moving out out of the attic space. That is not curing the problem, but the moisture will be removed and stop the mold problem from causing additional problems. Just a thought.
03-28-2010, 08:59 PM #14
Just had one of these myself recently, same scenario - blocked vents, no circulation, quite a few freeze then dry out cycles. The OSB contained Mold and was soft, recommended removal and replacement from the trusses up.
