    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Metal shingle roof
    Dont see many of these. Does the drip edge need to be under the shingle or is this used to hold the roofing in place.
    Phil Brody's Avatar
    Phil Brody Guest
    Default Re: Metal shingle roof
    caps the edge of the metal, installed correctly.
    James Slusser's Avatar
    James Slusser Guest
    After doing some research on Metro metal shingles web site it would appear that the pictures you show are correct installation. I am always glad for the updates on Inspections News as I learn so much from you guys and gals.
    Jim
    Thanks guys.
    AD thanks for the info.
