    Andy Jarchow's Avatar
    Andy Jarchow Guest
    Default Is this Modified Bituman??
    Hello all,
    What would you call this roofing? Is it Modified Bituman or should I just call it rolled roofing?
    As you can see from the photo 1 the roofing is held in place by a metal strip along the edge (some of it is held down). In some places I could see the nails popping up under the roofing material. I could also see areas where the plywood sheathing was coming loose and lifting.
    Any idea what the third pic. is of?
    Thank you for your help.
    Inspection Referral SOC
    Chicago IL
    Default Re: Is this Modified Bituman??
    Pics are too small to tell very well. Roof does look more like a Bitumen type than asphalt. However the patch in pic 3 looks like a combo of rubber and asphalt. The white thing in pic 3 is what we typically call a 'roof udder'. Some one smarter than I will know the real name. The device is typically used by electricians and AC guys to bring lines through the roof. They work very well. Don't remember seeing a white one before though. UV rating might be questionable.
    I would be telling the client that a good roofer will likely call for full replacement. Once you take the popping nails and possible loose substrate into consideration, repair isn't very feasible.
    www.aic-chicago.com
    Andy Jarchow Guest
    Talking Re: Is this Modified Bituman??
    Thank you Markus. Here is an overall shot of the roof and a little bigger pic. Hope this helps.
    Thanks again
    Chicago IL
    I thought you said we were talking about a roof, not a skate board park. Sure hope the owners don't have teenage boys
    www.aic-chicago.com
    Andy Jarchow Guest
    lol
    Philip's Avatar
    Philip Guest
    Looks like a rubber roof, especially the flashing and the lack of overlap for asphalt rolled roofing. Nail pops would be a concern.
