Thread: Help
    Sep 2007
    San Antonio TX
    Default ...
    [ATTACH]18967
    Default Re: Help
    Isn't that a skylight?
    Apr 2009
    Melbourne, FL
    Default Re: Help
    Its a skylight with copper flashing which has had a chemical effect on the wood shake roof cover (whitening). Not a problem.
    Thomas W. McKay
    ASHI Certified Inspector
    chris mcintyre's Avatar
    chris mcintyre Guest
    Default Re: Help
    It's a Velux skylight, they come with a flashing kit and I have never seen one with copper flashing. The flashing is aluminum as is the rest rest of the exterior cladding all with the same painted finish.
    I would guess that the bleached out area on the shingles/shakes is a result of cleaning the skylight.
    James Duffin's Avatar
    James Duffin Guest
    Default Re: Help
    My guess is galvanized flashing at the bottom and the zinc in the galvanized killed the mildew on the roof.
