08-05-2010, 04:37 PM #1
Modified roofing termination vs 90lb
I believe that when modified roofing is installed it must terminate vertically at headwalls. Is this the same case for 90lb (rolled roofing)?
08-07-2010, 08:49 PM #2
Re: Modified roofing termination vs 90lb
I guess nobody has an answer for you, Alex. I know I don't.
90 Lb roofing makes a poor roof on a residence, better just used for outbuildings and sheds. It takes a lot of nails and tar to make it work, and that will only be for a short time, IMO.
08-07-2010, 09:56 PM #3
Thanks anyway!
I would much prefer the Modified roofing as well, but just wanted to know if the manufactured specs for rolled roofing (90lb) were the same for Modified on the vertical termination. I can't seem to find it in any spec documents.
Thanks again,
Alex
08-08-2010, 06:20 AM #4
