Results 1 to 26 of 26
Thread: OSB eave
08-12-2010, 02:06 PM #1
OSB eave
Does anyone see a problem other than cosmetic with this OSB eave and it's peeling paint? The house was built in 1986.
08-12-2010, 02:44 PM #2
Re: OSB eave
Looks to me like the OSB has started to delaminate, which is a problem. I don't see it as a huge problem but it needs more than a coat of paint.
08-12-2010, 03:39 PM #3
Re: OSB eave
looks like an incompetant roofer used nails that damaged the osb. osb that is exposure 1 or exterior grade is approved for that application.
08-13-2010, 03:22 PM #4
08-13-2010, 07:11 PM #5
Re: OSB eave
08-13-2010, 08:14 PM #6
08-13-2010, 08:51 PM #7
Re: OSB eave
08-13-2010, 09:19 PM #8
Re: OSB eave
I edited my previous post to say what I meant , but I see that you got what I was saying.
When the roof sheathing is put on, it is cantilevered over the rafters for the overhang, changing over to a different material for the overhang would create many issues. Back when 1x6's where used, leaving the sheathing exposed was common practice (in my area) but with OSB I agree with John......
08-14-2010, 06:00 AM #9
Re: OSB eave
08-14-2010, 08:58 PM #10
Re: OSB eave
08-14-2010, 11:21 PM #11
Re: OSB eave
While I would like to see plywood used at gable and eave overhangs, I don't consider the use of OSB sheathing at these areas to be a defect.
Please, somebody prove me wrong by showing a credible source showing that it shouldn't be used, and for what reason, besides looks.
08-15-2010, 07:10 AM #12
Re: OSB eave
Both would need to be rated for Exposure 1, which is only temporary exposure to the weather during construction (basically intended to be less than 6 months).
PDF Download | APA - The Engineered Wood Association
Search "exposure" in those two documents (would not allow me to copy and paste). The '6 months' I got from the APA a long time ago as an industry excepted time period, not sure it if is documented anywhere, nonetheless, though, the above documents refer to 'during construction' and 'construction delay' - not to leaving it permanently exposed like that.
08-17-2010, 09:45 AM #13
Re: OSB eave
I finally got a day off, and figured I would look into this some more.
I did not spend any time reading your documents, because this one specifically states that OSB can be used at open soffits: http://www.apawood.org/pdfs/managed/...TOKEN=19279617
08-17-2010, 09:56 AM #14
08-17-2010, 12:41 PM #15
Re: OSB eave
Mr. Whitmore: It could perhaps be successfully argued that a soffit at the rake of a roof, because it is not a horizontal surface, does not constitute one that is only exposed on the underside.
08-17-2010, 02:00 PM #16
Re: OSB eave
Mr. Whitmore: But then, you are not the judge, right? And, if you actually could shoot down my argument (which I never really offered anyway - please peruse my original post to verify this for yourself), the ammunition would have been flying in my direction already, correct?
If you are that positive, why not contact the APA directly and ask them? Or, is it because YOU like a good debate?
08-17-2010, 02:53 PM #17
Re: OSB eave
08-17-2010, 08:57 PM #18
Re: OSB eave
Brandon, I can not prove you wrong or do I want to. My only reason is for LOOKS
08-17-2010, 09:45 PM #19
08-18-2010, 04:31 AM #20
08-18-2010, 04:34 PM #21
08-18-2010, 05:29 PM #22
Re: OSB eave
Brandon,
Did you read this part of your link?
(The file will not allow copy and paste, so go to page 2 of 2 to "Finishing - Soffit Applications" and then to "Expected Results and Performance". That "Expected Results and Performance" pretty much states what that photo shows.)
08-18-2010, 06:01 PM #23
Re: OSB eave
Hi Jerry,
Yes, I read that document multiple times before posting...........
I don't like seeing exposed OSB any more than the next guy.
I think that the OSB looks like it does in the original photo for at least a couple of reasons, including nail penetrations, exposure to moisture before being installed, etc.
08-19-2010, 02:43 AM #24
08-19-2010, 02:27 PM #25
08-19-2010, 02:45 PM #26
