Results 1 to 17 of 17
    Default This morning's roof
    C.Johnson's Avatar
    C.Johnson Guest
    Default Re: This morning's roof
    We just missed that storm here Looks like you got more coming too.
    Anacortes, Washington
    Did you use the broom to get to the roof? Probably safer than climbing a 24ft ladder in the snow!!
    //Rick
    Rick Bunzel
    WWW.PacCrestInspections.com
    360-588-6956
    Quote Originally Posted by Rick Bunzel View Post
    Did you use the broom to get to the roof? Probably safer than climbing a 24ft ladder in the snow!!//Rick
    Yup... step-through bars will get you on and off the roof OK, it's making sure the bottom of the ladder won't kick out that's the problem...
    ... and then, there's those pools of frozen water at the low spots under the snow...
    //Rick
    As a recent candidate for the Senate said, I am not a witch.
    Forgot my snowshoes...
    So
    You went on the roof toooooo
    Maybe find a soft spot to fall thru or just to get a winter tan ?
    I see the broom but I know you are not going to sweep the roof off,,,,,,right?
    So
    I did in fact sweep a couple spots so I could ID the type of roofing material. I also needed to look at the chimney top and flue.
    I figured that is what you were up to. Mine this morning was too frosty and too steep to get on
    Healdsburg, CA
    Is that creosote oozing out of the chimney on the right?
    Nope. That's the classic Philadelphia roofing tar chimney "crown".
    It helps lock in the natural juices and keeps the chimney extra moist and juicy. Yum.
    The clay liner was in remarkably good shape, probably due to the efficiency, or rather, lack thereof, of the 39 year old gas furnace.
    So, it looks like the typical 2 if not three story Philadelphia home. Did you stick the tall extension ladder in the snow drift or just set the feet on the ice below.
    Actually this was a sort of non-typical one story row, so I really wasn't doing anything very scary. I flipped the ladder feet around and jammed them down into whatever was under the snow on the front concrete patio. It felt secure, so up I went with my broom.
    Nov 2009
    St Paul, MN
    I haven't been able to inspect a roof since the end of November.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Forgot my sunscreen....
    Sorry, John. Good to see a bit of weather doesn't hold you back. In this town we can't drive two blocks without crashing in snow like that.
    James Whitman's Avatar
    James Whitman Guest
    You will need snowshoes to get around up there. The streets are just slick with ice around here. It's like the city had to shut down.
