Results 1 to 3 of 3
Thread: Fasteners - comp shingles
07-27-2007, 05:08 PM #1
Similar Threads:Last edited by Clay E White; 01-04-2008 at 02:48 PM.
07-28-2007, 01:20 AM #2
Re: Fasteners - comp shingles
I always recommend that all exposed fasteners be sealed of course, but I believe the reasoning behind this is that water is not shedding down onto those nails. (little exposure compared to the rest of the roof where water is draining onto areas below)
07-28-2007, 07:52 AM #3
Laziness.
Cost of sealing them over.
Looks, because it 'looks bad' when sealed over.
Yep. They should be sealed over with membrane and plastic roof cement.I'd think that if you are not allowed to install fasteners through the field shingles the same theory should apply to ridge or hip shingles - they could leak.
Of course, though, try cutting a small piece of membrane (asphalt impregnated fiber glass tape), you will end up with about a 2"-3" square or larger if it is to do any good. Apply plastic roof cement, set the membrane in it, then apply another bit a plastic roof cement over the membrane.
