Thread: Unconventional flashing?
08-04-2007, 06:19 PM #1
The rake boards have metal casement trim with L-flashing tuck behind the metal casement trim /lying ontop of the shingles. I haven't seen this configuration before. I can't see any issues with it - - what do you all think? Acceptable?
08-04-2007, 07:06 PM #2
Re: Unconventional flashing?
Not required but, I would like to see 1 more row of shingles to cover the flashing, NOT NAILED down but secured with adhesive. I don't see anything else.
08-04-2007, 07:48 PM #3
At the very least, the drip edge should be trimmed at an angle so it goes all the way down to the bottom, covering up the tops of all other flashings.
I can see where water can (will likely?) leak into that.
06-05-2011, 08:35 AM #4
It appears they bent the vertical side of the flashing to extend upon the roof deck, which is good. But I agree they should have run the drip edge all the way down until it meets the other roof line.
Randy Gordon, construction
