Results 1 to 9 of 9
Thread: 1/2 azz step flashing
09-23-2011, 02:01 PM #1
I know there should be a piece of flashing visible under each course. What exactly did he roofer do wrong to not get this right? How common is this error?
09-23-2011, 02:03 PM #2
Re: 1/2 azz step flashing
another pic
09-23-2011, 03:19 PM #3
The pictures are dark, so I can't tell for certain, but it looks like the flashing is wrong. Too short.
09-23-2011, 03:48 PM #4
09-23-2011, 03:51 PM #5
09-23-2011, 04:06 PM #6
09-23-2011, 04:15 PM #7
09-23-2011, 07:57 PM #8
John, I see more & more skilled work being performed by unskilled labor. It's cheap. Just out of curiosity, how old is the roof or house? Since you are in Maryland, what's the probability that the job was done by a crew that had just one guy who could speak English? I've become disgusted and flat out report that the work was done improperly by unskilled labor. If someone doesn't like it, prove me wrong.
Except for few builders, home building has gone to he'll by the way of bottom priced piece work and labor whose greatest claim to fame is a one room shack with a dirt floor. Hey guys! We're building 500K homes here. Not a shack in a third world country. I don't care if he's your uncle or nephew.
Okay, venting over
Stu, Fredericksburg VA
09-23-2011, 08:02 PM #9
John, if the flashing material for the step flashings is fairly long, it will span more than one exposure, therefore two rows before another step flashing is needed. That explains a visible flashing every other row.
As long as each flashing overlaps the last by a couple of inches, this does not as a rule lead to a leak.
Nailing thru the flashing will lead to a leak. That is probably what the goof did, nailed the second row thru the flashing.
