08-29-2014, 08:21 PM #1
Ridge vents Homemade? Shingles extedning over fascia?
I was on a roof today that had SO many issues its not even funny.
TWO questions
#1. Is there a requirement for how far a shingle should extend over the fascia?
#2. Is the below ridge vent homemade? I have never seen this before. It is not fully covered by the shingles and it also extended off the end of the roof a good 6-8"
08-30-2014, 07:35 AM #2
Re: Ridge vents Homemade? Shingles extedning over fascia?
Your pic doesn't show us anything.
Message to the 3 Corys.
08-30-2014, 07:42 AM #3
The ridge vent has a built in edge or louver, see them frequently. Keeps horizontal wind driven rain out.
Dom.
08-30-2014, 07:58 AM #4
09-12-2014, 08:47 AM #5
09-12-2014, 11:38 AM #6
I recommend baffled ridge vents over mesh ridge vents. The mesh ridge vents can be short circuited by winds as little as 5 mph that blow perpendicular to the mesh opening. The baffle pushes wind over top of the vent and creates the Bernoulli effect like Jacob mentioned.
09-12-2014, 08:00 PM #7
I believe the answer to the first question is typically 3/4".
09-20-2014, 04:55 PM #8
One should always read the directions printed on the shingle pack. I have done roofing, and seen lots of other's work. I rarely see roofers adhering to the directions on the pack. Typically, manufacturers recommend 1/2 to 3/4 inch extension beyond the drip edge (if the installer put drip edges on, many don't), otherwise same distance on whatever is there. I have seen edges extended two inches or more past roof edges, they invariably bend and break, exposing vulnerable materials.
