Results 1 to 10 of 10
Thread: Skylight Draft?
11-19-2007, 06:43 PM #1
Skylight Draft?
My mother in law is selling her home. There is no indication of any water leak on any of the inside surfaces. The home inspector indicated he felt an air leak around the skylights and recommended all of them be replaced prior to closing or compensated for. If there is an air leak wouldn't there also be a water leak and evidence of the water? I don't know too much about this, I just want to get some solid information I can give my mother in law on this.
Thanks,
Russ
11-19-2007, 06:53 PM #2
Re: Skylight Draft?
Some skylights open for ventlation. The seal on these can leak air, but no water may get to the seal for it to leak water. A lip keeps the water away from the seal.
11-19-2007, 06:59 PM #3
Re: Skylight Draft?
Russell,
Air leaks at skylights are very common and often do not result in water leaks. Most skylights around here sit on a raised curb. Generally, a 2x6 is attached to the roof framing and the perimeter of the curb is step flashed. Air leaks typically occur where the skylight rests on the curb, but can also flow through the voids between the gypsum wallboard and the framing. Caulking or foam sealant should be applied before the skylight is installed on the curb, but this is rarely done.
11-19-2007, 07:00 PM #4
Re: Skylight Draft?
The inspector may not have been commenting on any water leakage at all, only that he could feel a temperature change around the skylight indicating that a air leak in the seal is present.
Repair or give up some money for repairs would be the thing to do.
As a seller, I would offer up some cash and let the buyer fix it.
They won't, but then you won't have the headache of looking for a reputable contractor.
Thats Realtor talk.
Forgive me.
11-19-2007, 07:09 PM #5
Re: Skylight Draft?
The skylights are fixed, don't open. An air leak in the seal does make sense. The buyer didn't ask for repair $, they went straight asking for replacement$$$$$. Too greedy if you ask me. Can these seals be replaced? Any idea what a ballpark cost would be per unit?
11-19-2007, 07:33 PM #6
Re: Skylight Draft?
Yes. Simply remove the skylight dome and install a proper seal, some types of weatherstripping may work if the original seals are not available (some 'original seals' I've seen were nothing more than foam weatherstripping tape anyway).
No, but throw the buyer $100 per skylight if there are less than 3-4, if there are 3-4 or more, make it $50 or so each. This is because the person needs to get on the roof to fix them, and you will likely not get someone 'on the roof' for less than a couple of hundred bucks, and replacing the seal is not that had once on the roof with the weatherstripping.Any idea what a ballpark cost would be per unit?
As long as you don't break the dome, that is. (Which is why you want to give them $$$ and not do it yourself.)
11-19-2007, 08:49 PM #7
Re: Skylight Draft?
Thanks for all your help. I'll let her know she can offer a few hundred dollars at the closing for repairs.
Russ
11-20-2007, 09:34 AM #8
Re: Skylight Draft?
11-20-2007, 09:46 AM #9
Re: Skylight Draft?
Yes, she is trying to get everything in line ahead of time. My inlaws are elderly and not well and it appears that the buyers are trying to take some advantage of that. Luckily my mother in law's bitch factor has kicked in and she is done being pushed around.
11-20-2007, 10:35 AM #10
Re: Skylight Draft?
Tell her to throw in a bit of the middle age hot flashes and they'll back off from asking for any repairs.
They might even pay full asking price.
