Results 1 to 9 of 9
Thread: Cement tile roof questions
01-28-2016, 03:41 PM #1
2000 Cement barrel tile roof - Central FL - Block home with wood truss system - all truss chords are 2x4's - Sheathing is 1/2" plywood - Underlayment appears to be 30 lb felt - Reputable builder and all permits signed off on. Its stood the test of time with no visible problems. Typically I see 2x6 top chords - 5/8" sheathing and a water proof membrane such as a peel and stick or equal. Would all this be acceptable; your comments are appreciated. Thanks
01-28-2016, 04:02 PM #2
Re: Cement tile roof questions
Hello Mark - may I suggest checking what the code requires in your area. I know we don't do code, but it would particularly in a newer home provide us with a base legally acceptable building standard.
The other area is the loading distribution portion - what is the spacing of the truss framing system? If at 24 " o.c, are there deck clips, etc?
01-28-2016, 04:47 PM #3
01-28-2016, 05:44 PM #4
Most architects and engineers specify 5/8" roof sheathing under concrete tile, however, unless site specific engineering requires it, the code does not.
Installing concrete tile on 1/2" roof sheathing is an indication (in my opinion) of a cheapo contractor/builder - if they will do that, what else will they skimp on? (I know, I know, the answer is ... "everything".
01-28-2016, 05:53 PM #5
Thanks everyone for your help.
01-29-2016, 02:28 PM #6
You mean this wouldn't be acceptable?
01-29-2016, 05:13 PM #7
02-01-2016, 09:45 AM #8
The weight of the tiles was bowing the trusses down the whole roof. But it was much worse in the house, where almost every room had a hole in the ceiling where water was pouring in from above. It was a real mess.
02-22-2016, 09:48 PM #9
BTW, those are Concrete Tiles, are they not?
'Cement' is the stuff in the sack, like flour is an ingredient in bread.
OK, students, carry on inspecting.
