Results 1 to 3 of 3
Thread: Skylights , the dreaded topic
09-02-2020, 03:53 PM #1
is it a requirement for the corner joints to be soldered and/or sealed?
09-03-2020, 12:10 PM #2
Re: Skylights , the dreaded topic
Not that I am aware of. Certainly good practice to seal them but I don't think I have ever seen a field built flashing soldered. The sealant would tend to be under the metal so mostly would not be visible.
09-04-2020, 08:10 AM #3
That open corner should be clipped in under the other piece so that it keeps the corner closed. That's why it has that U hook type end.
Never seen anybody solder the corners. That flashing is mostly about water run off not so much sealing. The sealing is done by the stuff underneath.
