Thread: bird blocking?
03-22-2008, 12:08 PM #1
bird blocking?
This is a dry system, front of tile at eaves fastened with clips; backs nailed to ledger boards over felt; fancy tile roof about 18 yrs old. I call it bird blocking but it probably has a more technical name. There was none installed here. What can I say about it? Problem?
03-22-2008, 01:58 PM #2
Re: bird blocking?
Aviary Retention System sounds good.
03-22-2008, 03:29 PM #3
Re: bird blocking?
There are three terms, used mostly interchangeably:
- Bird stop
- Eave closure strip
- Eave riser strip
The last two are frequently used as: eave riser / eave closure strip.
03-22-2008, 03:31 PM #4
Re: bird blocking?
Bird Abuse
03-23-2008, 03:42 AM #5
03-23-2008, 05:33 AM #6
Re: bird blocking?
Are you guys just winging it?
03-23-2008, 10:10 AM #7
Re: bird blocking?
