Results 1 to 14 of 14
Thread: teeny roof drain
05-03-2008, 09:49 AM #1
teeny roof drain
Can someone 'splain to me why the drain on this flat(ish) front porch roof is soooo small?
It drains into a normal size downspout.
Similar Threads:Last edited by John Arnold; 05-03-2008 at 10:23 AM.
05-03-2008, 10:43 AM #2
Re: teeny roof drain
My guess would be that that was an area that had some ponding and not the main roof drain. Did the main roof drain by other means? Looks like a typical bathtub type of drain. Would get stopped up easily, especially by a roofed ball or something.
05-03-2008, 10:54 AM #3
This is the only drain on the front porch roof. The house is a twin, and the neighbor's drain is in the mirror opposite location, only the normal size. The downspout discharges into an old cast iron pipe directly below, so this is where the porch has been draining for a very long time.
05-03-2008, 11:24 AM #4
He found it in the back of the shop so he put it in.
Ron
05-03-2008, 08:38 PM #5
05-04-2008, 11:28 AM #6
Drain? Looks like a gun shot to me.
05-04-2008, 01:58 PM #7
I'm thinking it might be a lead flashing for about a 3/4'' or 1'' conduit,installed upside down.
05-04-2008, 08:18 PM #8
Foudation question
I have a question about a house I inspected a few days ago. The house is six years old and has a full basement. Three of the four sides of the exteior was fine but one side had foam attached to the foundation with some sort of "thinset" or morter material attached to it. It looked like it had alot of patch work done to it recently. Also, the inside of this wall had vertical crack extending from the top of the wall to the basement floor but it showed no sings of water.
Can anyone tell me why one side has this material on it?
I'll try to attach pictures.
05-04-2008, 09:02 PM #9
This should not be in the "Roofing" section, but what the hey...
It looks apparent to me that someone is trying to hide the exterior cracks with the thin set-- every poorly too, if I might add.
RR
05-05-2008, 04:44 AM #10
Thank you Richard... Sorry about the roofing section.
05-05-2008, 05:14 AM #11
05-05-2008, 01:35 PM #12
Thanks John... I recommended a strucural engineer to evaluate.
05-06-2008, 05:06 AM #13
While an explanation to John's may seem simple and obvious...try this one.
This is the "design team" at it again.
05-06-2008, 09:43 AM #14
Lazyiness or perhaps they didn't want to have a downspout in the front top of the house.
