Results 1 to 3 of 3
    Jun 2008
    Default tubular skylights
    My kitchen doesn't get very much natural light because the only window is under the carport. I was thinking about installing a tubular skylight since they are not too expensive and are easy to install.
    What do you think of these and have you had any expierences with them?
    tubular skylight
    Have a happy and safe 4th of July.
    Default Re: tubular skylights
    John,
    Those skylight types are used quite often around here. I've personally have never found a problem with them such as leakage.
    You have to be careful in the placement of them. They do put out a intense amount of light. It is almost like a fluorescent light.
    I really like the Velux Sun Tunnel skylight the best. If you use their flashing kit and follow their instructions they will not leak.
    VELUX SUN TUNNELâ„¢ Skylights - Welcome to VELUX America
