Results 1 to 12 of 12
Thread: Sag in roof
08-01-2008, 07:35 AM #1
Sag in roof
This house was built in 1960. Very noticeable sag was visible across the roof, although when I got in the attic framing looked pretty good. Any thoughts. Also, I tycically don't see metal shingle roof, are they 50 year life expectancy?
Mat
08-01-2008, 07:57 AM #2
Re: Sag in roof
It's odd thatyou saw no sagging on the roof rafters inside the attic. Visible deflection and sagging on the exterior generally means a similar interior condition on the rafters. The pitch of that roof is rather low and long. Do you have any interior pics of the attic?
08-01-2008, 08:07 AM #3
Re: Sag in roof
Those exterior door steps look bogus in your photos Mathew, did you measure the top risers?
08-01-2008, 08:39 AM #4
Re: Sag in roof
Exterior concrete needs to replaced. The house was moved and the ground was not preped correctly so the patios and decks basically sunk, in addition to the garage. Here are some more pics.
08-01-2008, 08:42 AM #5
Re: Sag in roof
This is what is left of the garage slab.
08-01-2008, 08:50 AM #6
Re: Sag in roof
Looks like a contractors dream.........................just open your checkbook and keep writing. garage wall looks lower than the rest of the hose, pooor flatwork,siding in poor condition, etc.
08-01-2008, 09:28 AM #7
Re: Sag in roof
What part of the country is this house in?
I suspect that house is a "scrape?"
08-01-2008, 09:32 AM #8
Re: Sag in roof
Peoa Utah, which is outside Park City about ten miles. Basically the North central part of the state. What is a scrape?
08-01-2008, 11:05 AM #9
Re: Sag in roof
Matthew,
A "scrape", as in the front blade of a bulldozer. Read "Scraaaape!"
Metal shingle life expectancy depends on the manufacturer. If Decra and if not damaged by walking or other mechanical means; yes, I believe they are supposed to be a 50 year roof. However, I have never liked their roof/wall flashings which will almost certainly will not last 50 years.
08-01-2008, 07:30 PM #10
Re: Sag in roof
The attic framing doesn't look too bad. I think that I'd be more concerned about everything that's UNDER the roof though - yikes! I assume they use levels out there(?).
08-02-2008, 05:19 AM #11
08-04-2008, 07:54 AM #12
Re: Sag in roof
The basic problem with the roof frame (independent of foundation/slab considerations are 1) The posts under the ridge should be removed as they are supporting limited area's and they are transfering the load to the floor below which roofs are not designed to do. 2) The collar ties are not cut correctly (square cut). They should be cut at the angle which is parallel to the pitch of the roof. I would also run strapping across the underside of the collar ties as one does on the underside of a deck. I don't see this as over-reporting if I stick to the dificiencies. Chris Bittner
