    Ron Bishop's Avatar
    Ron Bishop is offline Member
    Jun 2007
    Shasta Lake, California
    Default unusual roofing material
    I ran across this roofing material today. It is an aluminum tile with a sprayed on granule similiar to what you would find on composition shingles. The material was so soft that i could hardly walk on it. The shingles were nailed in from the top without neoprene washers. Has anyone seen this material before??
    EMSL Laboratory Testing Services
    Ron Bishop
    Shasta Lake, Ca.
    Jerry Peck's Avatar
    Jerry Peck is online now Member
    Default Re: unusual roofing material
    Quote Originally Posted by Ron Bishop View Post
    I ran across this roofing material today. It is an aluminum tile with a sprayed on granule similar to what you would find on composition shingles. The material was so soft that i could hardly walk on it. The shingles were nailed in from the top without neoprene washers. Has anyone seen this material before??
    I've seen it (or something similar) on a lot of commercial buildings.
    Jun 2007
    I've seen it installed once. It was several years ago, and I don't have the product info. any more (sorry). I wrote it up in the report that it looked like a poor design that would probably leak------I was told later on that the roof leaked soon thereafter.
    A.D. Miller's Avatar
    A.D. Miller Guest
    RB: They are steel, not aluminum.
    Gerard Roofing Technologies - Stone Coated Steel Roofs
    Granutile - a Stone Coated Metal Roofing Tile from ATAS International - Manufacturers of Metal Roofing, Walls, Ceilings, and Structural Components
    Stone Coated Steel Roofing - Stone Coated Metal Tile - Decra Roofing Systems
    John Kogel's Avatar
    John Kogel is online now Member
    Yeah did I say use a magnet? This one fooled me till I climbed back up with a magnet. They are indeed steel. Mine are nailed better than yours.
