Welcome to InspectionNews.
Registration is FREE!
The Cost Of Business
Old 05-20-2009, 07:22 PM
Trent Tarter's Avatar
Trent Tarter Trent Tarter is offline
Correct name for these
Whats the correct name for these. I just want to call them eave supports, but I know that there's a correct name for them.
Home Inspector Essentials. The BEST prices for inspection tools.
Old 05-20-2009, 07:59 PM
Bruce King Bruce King is offline
Re: Correct name for these
Corbel
Old 05-20-2009, 08:37 PM
That's it, thanks Bruce.
Old 05-20-2009, 09:36 PM
Gunnar Alquist's Avatar
I was thinking split and weathered.
Reality is a crutch for people who can't handle drugs.
Old 05-20-2009, 10:03 PM
Squirrel Roost
Ted Menelly
Castle Home Inspection Services
www.inspectmycastle.com
  #6 (permalink)
Old 05-20-2009, 10:38 PM
Rick Hurst's Avatar
Trent,
Most inspectors in this area call them a rustic decorative beam, but Bruce is correct with it being a corbel.
The ones I see are mostly decayed on the top due to water not draining off of them. There is a builder here in our area that any inspector in this area will know that used these back in the 70's and 80's on many homes.
  #7 (permalink)
Old 05-21-2009, 12:34 AM
Mike Truss Guy's Avatar
Mike Truss Guy Mike Truss Guy is offline
What I find interesting about those things is they're not usually really important to the structure. You can just as easily support those fly rafters with sheathing and connection to the fascia board. Of course nobody in their right mind should ever stand on those things anyway - the sheathing is usually suspect unless it's been well maintained throughout it's entire life. The whole thing serves mostly a cosmetic purpose.
Mike The Truss Guy
www.WoodTruss.org
  #8 (permalink)
Old 05-21-2009, 07:35 PM
Lou Collier Lou Collier is offline
I have always heard them referred to as brackets.
Architectural brackets
They are usually on houses from the 20's and 30's around here. They support the barge or fly rafter and the roof overhang.
I would disagree that they have no purpose. Many houses here have sagging overhangs where the brackets have pulled away from the walls. Unless the overhang is less than 16 inches or so, they are needed to support the roof.
  #9 (permalink)
Old 05-21-2009, 07:47 PM
John Dirks Jr's Avatar
John Dirks Jr John Dirks Jr is offline
when all else fails,
"exterior wood components"
John Dirks Jr - Arundel Home Inspection LLC
Maryland Home Inspection - Maryland Home Inspectors - Maryland Radon Testing - Baltimore County Rental Inspection
  #10 (permalink)
Old 05-22-2009, 03:56 AM
A.D. Miller's Avatar
A.D. Miller A.D. Miller is offline
JD: My, but Freud would have field day with that particular handle.
"What the plainspoken man lacks in subtlety he makes up in clarity." - A.D. Miller
www.texasinspector.com
  #11 (permalink)
Old 05-22-2009, 09:37 AM
Rick Sabatino Rick Sabatino is offline
The corbels on my house are only attached to the 1x8's under the stucco and lath. That makes them hard to replace.
Here they are pigeon roosts.
Rick Sabatino
Sabatino Consulting, Inc.
Oak Park, IL
  #12 (permalink)
Old 05-22-2009, 12:35 PM
fritzkelly fritzkelly is offline
I always called them "lookouts". From wickepedia:
In architecture a corbel (or console) is a piece of stone jutting out of a wall to carry any superincumbent weight. A piece of timber projecting in the same way was called a "tassel" or a "bragger".
I thought a corbel was at the top of a column.
  #13 (permalink)
Old 05-23-2009, 07:00 PM
Glenn Duxbury Glenn Duxbury is offline
Hi, all &
Have to agree with Lou...
Them's "brackets" -as I've always know 'em !
Corbels usually retained for interior fancy bits...
CHEERS !
Glenn Duxbury, CHI - License #47730
-Glenn Duxbury, CHI
  #14 (permalink)
Old 05-25-2009, 12:06 PM
Jerry McCarthy's Avatar
I agree with Glenn; "Conice Brackets" Refer; Construction Glossary and Repeating Cornice/Frieze Brackets - Interior and Exterior in Wood and PVC for Porch, Doorway, etc - from Vintage Woodworks and Cornice Bracket
http://www.sfbayareaexpertbuildingconsultants.com/
  #15 (permalink)
Old 05-25-2009, 12:48 PM
From Jerry's Construction Glossary: Lookout- A short wood bracket or cantilever that supports an overhang portion of a roof.
  #16 (permalink)
Old 05-25-2009, 04:54 PM
Most end wall overhangs are under 16" - at least where I live. In fact many are under 6". Like I said the fly rafters can be supported by connection to a structural fascia board.
Quote:
Originally Posted by Glenn Duxbury View Post
Hi, all &
CHEERS !
All of these posts bring up an interesting point. Construction terminology varies greatly depending on where you live.
Mike The Truss Guy
www.WoodTruss.org
FREA Home Inspector Insurance
Similar Threads
Is this correct???? JIM MURPHY Attic Areas: Home Inspection and Commercial Inspection 23 02-17-2009 02:45 PM
foundation this can be correct tim reaves H E L P ! 8 12-12-2008 12:31 PM
Is this ground correct? Marc M Electrical Systems: Home Inspection and Commercial Inspection 9 11-28-2008 06:32 AM
Look at photo...is this a correct application ? Gene South Plumbing System: Home Inspection and Commercial Inspection 12 08-27-2008 08:10 PM
Correct construction???? JIM MURPHY Building Interior: Home Inspection and Commercial Inspection 7 08-07-2008 02:35 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Ad Management by RedTyger
