Old 06-16-2007, 04:04 AM
David Banks David Banks is offline
Valley material
What type of material is this? Should it be painted?
Dave
Home inspection
Old 06-16-2007, 05:44 AM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Re: Valley material
Copper. No need to do anything except be thankful they didn't use something else.
Eric Barker
Barrington, IL
Old 06-16-2007, 06:24 AM
Mark Nahrgang Mark Nahrgang is offline
Re: Valley material
Eric,
Your post seemed pretty confident that it's copper, so I'll ask you my follow-up question. And this is an honest question, I'm not being argumentative.
I always thought copper had either a new "golden" color, or a nice green patina. This seems to be more of an aluminum or lead color. Apparently copper roofing comes or patinas in this color too. Do you know what causes that?
Thanks for any education you're willing to share on this point.
Mark
Mark Nahrgang
Kingdom Inspection Network Group
MarkNahrgang@KingdomInspections.com
Old 06-16-2007, 07:51 AM
Re: Valley material
To me, it's flatness told me it must be some type of metal.
I would have thought lead from its color.
Could also be terne.
It does look to be soldered.
I'm not saying it is not copper, but I would have expected a slightly greenish color for it to be copper.
Old 06-16-2007, 07:58 AM
Chad Fabry's Avatar
Chad Fabry Chad Fabry is offline
Re: Valley material
I'm 90% sure that it's terne coated steel. Yes, it should be painted.
Chad Fabry, Rochester, NY
StructureSmart Home Inspections, Inc.
www.structuresmart.com
  #6 (permalink)
Old 06-16-2007, 09:34 AM
Robert Schenck's Avatar
Robert Schenck Robert Schenck is offline
Re: Valley material
Aside from what type of material it is, … to me it’s very awkward and unappealing. It looks like an over-sized gutter. Design wise, I can see it catching a large amount of rain water and channeling it down to one area, … which I think in turn will cause premature wear on the shingles in that area of the roof. That's my 2 - cent opinion.
Robert
Roberts Home Inspection Service
  #7 (permalink)
Old 06-16-2007, 12:51 PM
Re: Valley material
Mark,
I hope I didn't jump the gun. Chad now has me wondering. I agree about the color. In my area such detail would be done in copper.
Eric Barker
Barrington, IL
  #8 (permalink)
Old 06-16-2007, 01:10 PM
Richard Rushing's Avatar
Re: Valley material
Coated steel roofing-- my guess.
Rich
Richard Rushing, HCRI
Duncanville, Tx.
  #9 (permalink)
Old 06-16-2007, 02:58 PM
Re: Valley material
Quote:
Originally Posted by Robert Schenck View Post
Design wise, I can see it catching a large amount of rain water and channeling it down to one area, ...
That's exactly what it is designed to do.
Does not cause a problem if the end of the flashing is turned down and out.
There really is no other good way to handle the water collected between those three roof surfaces. Sure, you could put in a flat roof, other than losing the roof style to a raised flat center, you have not changed anything - the water from that flat roof and the other two roofs will STILL need to be drained off someplace ... over the shingles.
(Unless they install a roof drain, which is very seldom done on residential roofs - I've seen some, but not many, and not unless there is a parapet wall around the perimeter too.)
  #10 (permalink)
Old 06-17-2007, 03:02 PM
Re: Valley material
Thanks all. It did not look like lead or copper. Probably terne.
Hey Robert. Do you realize you put a tractor in the most exclusive street in my town! The Gall!
Dave
Similar Threads
Valley weave Greg Jenkins Roofing System: Home Inspection and Commercial Inspection 2 06-17-2007 05:15 PM
Valley rafter gusset Greg Jenkins Attic Areas: Home Inspection and Commercial Inspection 3 06-11-2007 01:21 PM
Primary drain line material John Stephenson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 05-10-2007 06:18 PM
Mesa jump-starts pool safety - East Valley Tribune Brian Hannigan Pool and Spa: Home Inspection and Commercial Inspection 0 04-21-2007 12:11 PM
Draft hoods , combustible material Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 6 04-15-2007 10:12 PM
vB.Sponsors
Ad Management by RedTyger
