Re: exposed nail heads
Wes,
There should be flashing behind the siding that laps onto the top run of shingles, "best practice" would be to leave this flashing exposed and not put nails in it with the last run of shingles. Most people prefer not to see the flashing, so the last run of shingles are added on top of the flashing.
So as long as there is flashing under that top run of shingles, and as the others said, the nails are sealed, there should not be a problem.
BTW, I think the self sealing theory is a bit of a stretch, you should be able see the sealant.
When I was younger I could remember anything, whether it happened or not. - Mark Twain
