Old 07-11-2007, 09:54 PM
Larry Vance Larry Vance is offline
Roof Sheathing Repair?
How many metal covered holes are allowed?
HomeGauge Reports
Old 07-19-2007, 09:38 AM
Mike Drorbaugh's Avatar
Mike Drorbaugh Mike Drorbaugh is offline
Re: Roof Sheathing Repair?
Quote:
I put this question to the answer guys at APA--The Engineered Wood Associaiton and got the following guidelines:
1) If the hole is 6-inches or less we are not too concerned.
2) If the hole is larger than 6-inches we would suggest structural blocking, located adjacent to the hole edge closest to the unsupported panel edge. Blocking should be parallel to the unsupported panel edge.
3) If the edge of a hole 6-inches or larger is less than 24-inches from an unsupported panel edge we suggest following the panel edge support recommendations for narrow width roof sheathing as provide in APA Technical Note R275 (copy attached).
4) Any hole with any dimension larger than the distance between supports should be engineered.
These are just suggestions or guidelines and are based on the assumption that no additional loads are associated with the opening (e.g., an HVAC unit supported by roof sheathing).
Another question is what happens to the poor individual who happens to step on the roofing over the hole?
Mike Drorbaugh
Old 11-02-2009, 02:28 PM
Todd Strickland Todd Strickland is offline
Roof Repair
Thank you, Mr. Drorbaugh. I've been wanting to know the code on that.
Best,
AeGis Roofing
Fredericksburg, Va Roofer
Old 11-02-2009, 06:30 PM
Scott Patterson's Avatar
Re: Roof Repair
Quote:
What was cited is not code. It is a trade association guideline. Big difference between the two.
Looks like that sheet of OSB is already sagging, but that could be just the angle of the camera.
Scott Patterson
Old 11-02-2009, 07:30 PM
Ryan Stouffer Ryan Stouffer is offline
What are those metal rods coming down from the ceiling of the roof?
  #6 (permalink)
Old 11-02-2009, 08:46 PM
Jerry Peck's Avatar
Quote:
HVAC unit.
Which those GUIDELINES state make that unacceptable, as do the size and number of those openings.
  #7 (permalink)
Old 11-03-2009, 06:23 AM
Ahhh, ok.
  #8 (permalink)
Old 11-03-2009, 06:30 AM
Are you referring to the sheathing when you are using the term unsupported panel edge?
  #9 (permalink)
Old 11-03-2009, 09:41 PM
John Kogel's Avatar
John Kogel John Kogel is offline
I believe it's the long seams between the rafters being referred to. That was 2007, BTW.
  #10 (permalink)
Old 11-03-2009, 11:36 PM
Brandon Whitmore Brandon Whitmore is offline
We know what the APA has to say, but what about the shingle manufacturers.
Similar Threads
Scuttle ladder repair Frank Bombardiere Attic Areas: Home Inspection and Commercial Inspection 18 02-11-2008 10:36 AM
3/8" plywood roof sheathing Kenton Shepard Attic Areas: Home Inspection and Commercial Inspection 10 07-26-2007 02:08 PM
Wood Structural Panel Sheathing or Siding Used to Resist Combined Shear & Uplift Brian Hannigan Building Envelope: Home Inspection and Commercial Inspection 0 05-23-2007 01:16 PM
Recall to Repair Gas-Fired Hot Water Boilers Brian Hannigan Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 1 04-05-2007 02:31 PM
Plaintiffs claim homes poorly constructed, sue for repair costs - Merced Sun-Star Brian Hannigan Expert Witness and Defect Litigation: Home Inspection & Commercial Inspection 0 03-27-2007 01:03 AM
vB.Sponsors
Ad Management by RedTyger
