Old 04-03-2007, 01:47 AM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Roof Jack w/ Neoprene Boot At B Vent
The roof jack at the B vent for the water heater has a neoprene boot. There should be a 1" clearance between a B vent and combustible materials so the use of a neoprene boot at a B vent would be improper, right?
(First pic taken with CopterCam. )
Old 04-03-2007, 07:07 AM
Michael Thomas's Avatar
Re: Roof Jack w/ Neoprene Boot At B Vent
CoptorCam?
Old 04-03-2007, 08:20 AM
Scott Patterson's Avatar
That is a great picture. The boot is completely wrong for that type of application. That type of boot jack or vent stack boot is made for plumbing vents and not "B" vents. It needs to have a metal transition cone with a storm collar to keep the water out.
Scott Patterson
Old 04-03-2007, 09:13 AM
Richard Rushing's Avatar
As Scott properly identified, that is a plumbing vent boot and is not rated for a ombustion flue.
The flashing should be of the metal type rated for a B-vent combustion flue.
Richard
Old 04-03-2007, 11:33 AM
That's the way I wrote it up. Thanks for confirming my suspicions, guys.
  #6 (permalink)
Old 04-03-2007, 01:52 PM
Copter-Cam!!!
RR
  #7 (permalink)
Old 04-03-2007, 02:14 PM
Martin lehman's Avatar
Martin lehman Martin lehman is offline
Those boot are worthless. They fail over time or if installed wong (done alot) and basically end up holding water - bad concept IMHO.
Home inspection
Similar Threads
Crawlspace vent fan Kevin Luce Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 11 05-18-2007 09:13 PM
vB.Sponsors
Ad Management by RedTyger
