Old 08-04-2007, 07:19 PM
Clay E White Clay E White is offline
Unconventional flashing?
The rake boards have metal casement trim with L-flashing tuck behind the metal casement trim /lying ontop of the shingles. I haven't seen this configuration before. I can't see any issues with it - - what do you all think? Acceptable?
Home inspection
Old 08-04-2007, 08:06 PM
Rick Cantrell Rick Cantrell is offline
Re: Unconventional flashing?
Not required but, I would like to see 1 more row of shingles to cover the flashing, NOT NAILED down but secured with adhesive. I don't see anything else.
Rick Cantrell
Old 08-04-2007, 08:48 PM
At the very least, the drip edge should be trimmed at an angle so it goes all the way down to the bottom, covering up the tops of all other flashings.
I can see where water can (will likely?) leak into that.
Home inspection
Similar Threads
Skylight flashing dan orourke Roofing System: Home Inspection and Commercial Inspection 3 07-06-2007 08:00 PM
Kickout flashing John Stephenson Roofing System: Home Inspection and Commercial Inspection 11 06-25-2007 12:32 AM
valley flashing John Stephenson Roofing System: Home Inspection and Commercial Inspection 2 06-22-2007 07:37 PM
Counter flashing John Stephenson Building Envelope: Home Inspection and Commercial Inspection 0 06-22-2007 05:16 PM
Chimney Flashing Warren Alderman Attic Areas: Home Inspection and Commercial Inspection 3 04-06-2007 09:43 AM
vB.Sponsors
Ad Management by RedTyger
