Old 08-05-2007, 08:31 AM
Clay E White Clay E White is offline
Terminology help
Home inspection
Old 08-05-2007, 12:29 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Re: Terminology help
Clay,
That is much less of a problem than many I see. Anyway, I would call it "soffit end at intersection with lower roof".
Bruce Breedlove
www.avaloninspection.com
Old 08-05-2007, 04:49 PM
Richard Rushing's Avatar
I would just reference; 'The upper-level soffit transition to lower-level roof covering".
Richard Rushing, HCRI
Duncanville, Tx.
Old 08-05-2007, 06:17 PM
Is that rotted out up in there?
The shingles look like they did down right up under that soffit.
I always referred to it as 'soffit return at roof intersection'.
What's strikes me as really funky is that metal off to the right at the gable. That is designed for, and intended for, use on horizontal surfaces such as soffits, not vertical surfaces like that - I can see that thing leaking like crazy with wind driven rain, or even normal rail if that area is large enough, and that could be the source of what looks like a leak (the dip in the shingles I pointed out).
Did you poke you hand down on those shingles and sheathing to see?
Old 08-05-2007, 06:40 PM
James Duffin James Duffin is offline
When I see this situation, I usually suggest that flashing be installed so water never reaches the soffit/roof intersection.
  #6 (permalink)
Old 08-05-2007, 08:12 PM
Michael Thomas's Avatar
Michael Thomas Michael Thomas is online now
Do you have a wider view of this area of the roof?
  #7 (permalink)
Old 08-11-2007, 09:27 PM
Matt Hawley Matt Hawley is offline
If it's a front entry way I word it as:
There is a void along the South side front entry soffit and roof transition. Recommend making the neccessary repairs to prevent vermin and or pest from intruding.
Similar Threads
garage door terminology wes owens Exterior Systems: Home Inspection and Commercial Inspection 4 06-09-2007 01:29 AM
Service point terminology Michael Thomas Electrical Systems: Home Inspection and Commercial Inspection 12 06-05-2007 11:07 AM
vB.Sponsors
Ad Management by RedTyger
