Old 08-22-2007, 12:13 AM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Plumbing Vent Roof Jack At Valley
Ordinarily I would blame a lazy or inattentive plumber for placing a plumbing vent so close to a roof valley. But in this case this was an existing vent that years later ended up too close to a valley that was created when a rear addition was built.
Anyway, the valley flashing was stepped and notched to accomodate the roof jack flashing. Does anyone see a problem with the flashing for the roof jack encroaching into the valley? What comments would you make?
Bruce Breedlove
www.avaloninspection.com
F.I.R.E. provides fireplace education, consulting services, fire investigation and litigation support across the United States.
Old 08-22-2007, 04:09 AM
David Banks David Banks is offline
Re: Plumbing Vent Roof Jack At Valley
Bruce. I got this from Inspection News a while back. Just change chimney.
CHIMNEY IN VALLEY:
: There is supposed to be a 36" wide moisture barrier underlayment at all valleys, 18" to either side if installed correctly, Therefore no chimney(s), plumbing vent(s), or flue stack(s) should be placed within 18" of a valley. Penetrations to the moisture barrier may eventually leak and these areas will require further monitoring and sealant application if not relocated and installed correctly.
Dave
Old 08-22-2007, 01:50 PM
Jerry Peck's Avatar
We went through this recently, and it depends on how valleys are done in your area. (That's what was decided here.)
Many areas install a 16" wide valley metal in the valley, which extend out from the center 8" to each side, stay outside that valley metal and there is no problem.
Other areas install a 36" wide roll down the center of the valley, which extends out 18" ...
I'm not sure that the flashing in your photo is even 8" out from the center of the valley, and that is the minimum distance to clear the valley metal.
Casey, O'Malley & Associates Home and Commercial Education Classes and Conferences
Similar Threads
vent flashing/valley RobertSmith Plumbing System: Home Inspection and Commercial Inspection 18 08-06-2007 05:23 PM
Plumb vent near valley dan orourke Roofing System: Home Inspection and Commercial Inspection 5 07-06-2007 02:14 PM
Plumbing vent Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 1 06-27-2007 04:53 PM
Plumbing vent height John Stephenson Plumbing System: Home Inspection and Commercial Inspection 17 05-23-2007 01:44 PM
Roof Jack w/ Neoprene Boot At B Vent Bruce Breedlove Roofing System: Home Inspection and Commercial Inspection 6 04-03-2007 02:14 PM
vB.Sponsors
Ad Management by RedTyger
