Old 09-13-2007, 07:50 AM
dan orourke dan orourke is offline
Copings
Old 09-13-2007, 08:02 PM
Re: Copings
Yes.
Yes, and Yes.
Old 09-14-2007, 06:39 PM
Re: Copings
Quote:
Originally Posted by dan orourke View Post
Thanks, Jerry. Rather than the sealant, how should the interface joints between panels be detailed to prevent leakage, soldered?
Soldered or a metal crimp lock joint - or both, metal crimp lock joint which is then soldered.
Mostly though, you only find the soldered joints on copper parapet wall coping caps.
Home inspection
vB.Sponsors
Ad Management by RedTyger
