Results 1 to 15 of 15
    Default Gutter in the attic!
    This is from an inspection today. This is a gutter that is attached along a chimney in the attic. Apparently the owner could not stop the leakage around the chimney so he fabricated a small gutter. Attached it to the brick and then attached a drain to a gallon jug!
    AHIT InspectIt Home Report
    Default Re: Gutter in the attic!
    Looks like he could use a larger jug.
    Jul 2010
    Wisconsin
    Only leaked on the one side? Or is this a wrap around porch?
    Quote Originally Posted by Mike Kleisch View Post
    The other sides also leaked, but they are on the outside.
    Dummy. You want to use a big shallow pan so the water evaporates in the summer, for zero maintenance.
    My thoughts too ... and set that shallow pan on some brick which will heat up and help the evaporation.
    I also wondered how many inches of rain he gets to the gallon?
    Who puts carpet on the attic floor?
    Fort Worth, Texas
    Now, I ask you. Did you get paid from Walmart for the advertising. That whole scene looks like the Walmart shoppers photos you always see floating around. And the Walmart box along side it all. You just cannot make that stuff up.
    Ted Menelly, Castle Home Inspection Services
    www.inspectmycastle.com
    Fort Worth, Keller, Southlake, Plano, Flower Mound, DFW, TX
    It soaks up the leaking water and let's it evaporate without leaking down to the ceiling below.
    May 2007
    Marietta, GA
    I do have to applaud the guy's creativity. I just wonder if he disclosed that as a leak or not .
    Quote Originally Posted by Bronson Beisel View Post
    I'm sure they did.
    On the listing form
    Under AMENITIES, OTHER, they listed RAIN WATER COLLECTION SYSTEM
    Aug 2011
    So, you wrote up, "Replace jug with condensate pump"
    Nope, this is proof that we just do not make this stuff up. It's stuff like this that make this a fun profession. Finding stuff like this just makes your day!
    Mar 2012
    Monroe, Washington
    You guys have no appreciation for a good cistern system and that saving our planet's resources is a grass roots mandate that starts at one's home
    Aug 2008
    Pleasant Hill, Iowa
    Nice Humidifier
    Dan Hagman
    ProSite Home Inspections
    Des Moines, Iowa
