Old 12-03-2007, 02:58 PM
Skylight installation
Old 12-03-2007, 03:54 PM
Scott Patterson's Avatar
Re: Skylight installation
Quote:
Originally Posted by Jeff Eastman View Post
Roofer says this installation is wrong but I'm not seeing it. I didn't write up any defects on it. Do you see something I'm not??
A couple of common things with skylights;
If it is over 30" in width it needs a cricket
If the slope is 3/12 or less pitch it needs a 4" curb or more
Also on the bottom edge the flashing should be on top of the shingles, not under them. I could not tell in your picture.
Scott Patterson
Old 12-05-2007, 11:10 PM
Ah yes, skylights..... I've paid out a few bucks on them before. The real stinger is that you can't always see an improper install in a visual inspection.
I actually had one in my own house about a year after I had the roof replaced. After it was torn apart you could see that the upper 'L' flashing was snipped a bit too far at the crease and it led to a leak. I was surprised how small of an imperfection led to a leak.
And I know.... I probably didn't have to pay for the one I did but sometimes it's just easier.
As for the one in the picture, I don't see the problem either.
Old 12-06-2007, 05:33 AM
Rick Cantrell Rick Cantrell is offline
Scott
Of course you are correct in saying a cricket is needed if the skylight is => 30". I know it is not our job to design a repair, only to report that a repair is needed, but how would / could one make a cricket for a skylight?
Rick Cantrell
Old 12-06-2007, 06:56 AM
Quote:
If it is over 30" in width it needs a cricket.
Quote:
Originally Posted by Rick Cantrell View Post
Scott
I've been trying to wrap mu mind around that ... where does it state a skylight wider than 30" needs a cricket?
A skylight is different than a chimney or wall in that the wider a chimney or wall gets, the more water which will build-up and collect on the high side of it, however, with a skylight, before the water builds up to a point where it could overflow its flashing (the reason for the cricket) the water would overflow the skylight itself because the skylight is not that high.
Unless I am missing something.
  #6 (permalink)
Old 12-06-2007, 07:15 AM
Well, I think that I should have said that anything that forms a penetration in a roof that is >30" should have a cricket. Chimney, skylight, ect. This is to keep the water from overflowing the flashing, just as Jerry pointed out. Most of the skylights that I have seen that are big enough to have a cricket are on commercial projects and the cricket is built into the flashing on the high side of the unit.
Scott Patterson
  #7 (permalink)
Old 12-06-2007, 07:58 AM
Jerry
My first thought was that a cricket did not apply to skylights. So I looked it up in the 2006 IRC
" R905.2.8.3 Crickets and saddles. A cricket or saddle
shall be installed on the ridge side of any chimney or penetration
more than 30 inches (762 mm) wide as measured
perpendicular to the slope..."
Now, how to build a cricket for a skylight?
Rick Cantrell
  #8 (permalink)
Old 12-06-2007, 10:18 AM
Jim Luttrall Jim Luttrall is online now
Notice it is only required if perpendicular to the slope.
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #9 (permalink)
Old 12-06-2007, 10:26 AM
BARRY ADAIR's Avatar
BARRY ADAIR BARRY ADAIR is offline
Quote:
The only ones that arent perpendicular are the round models...or did I miss something, again?
Perpendicular - Wikipedia, the free encyclopedia
AB=downward slope of the roof plane CD=skylight head flashing in the wiki example
Residential-Commercial-Construction-EIFS-Infrared Thermography
  #10 (permalink)
Old 12-06-2007, 10:36 AM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Thanks Scott!
You've presented a whole new thought process to tax the aging brain cells. I never have given consideration to a skylight cricket and have never seen one that I can remember. Now with Rick's IRC post I'm in overload.
No more for today ok?
Eric Barker
Barrington, IL
  #11 (permalink)
Old 12-06-2007, 11:28 AM
Quote:
The only ones that aren't perpendicular are the round models...or did I miss something, again?
Com'on Badir, think outside the box.
Is a square skylight a just a square or a could it be a diamond shape??
How many chimneys have you seen that are on a diagonal in relationship to the roof plane?
Allen, Texas 75002
  #12 (permalink)
Old 12-06-2007, 11:49 AM
Michael Thomas's Avatar
The Velox installation instructions for both non-self-flashing and self-flashing skylights make no mention of crickets at any width or orientation.
  #13 (permalink)
Old 12-06-2007, 04:49 PM
Looks like what I was missing was the "or penetration".
  #14 (permalink)
Old 12-06-2007, 06:31 PM
Quote:
Most that you will see for residential use will be smaller than 30", so it is not an issue.
Scott Patterson
  #15 (permalink)
Old 12-06-2007, 10:20 PM
Richard Rushing's Avatar
From what I can tell from the photo, the bottom flashing of the skylight should NOT be under the singles. As is, the water running down the side channels allows for running up under the lower shingles.
Richard
Richard Rushing, HCRI
Duncanville, Tx.
  #16 (permalink)
Old 12-06-2007, 10:42 PM
If you look closely, I think we can see the head of the skylight in both photos, if I am reading the lap of the shingles correctly.
If this is the case, then the "ears" of the flashing on each side form dams which would hold water at the head of the skylight rather than letting the water flow down and around the skylight. If the slope of the roof is shallow enough in relation to the height of the obstruction, then water could back up under the shingles or up and over the curb which looks a little short.
Allen, Texas 75002
  #17 (permalink)
Old 12-07-2007, 05:42 AM
sorry, I postet in the wrong thread
Rick Cantrell
  #18 (permalink)
Old 12-17-2007, 06:33 PM
Quote:
Originally Posted by RobertSmith View Post
Is the conclusion of this post that a cricket is needed? The code posted seems to indicate so "...or penetration more than 30 inches"....
Yes..
  #19 (permalink)
Old 10-13-2008, 07:47 AM
LR HOME SOLUTIONS LR HOME SOLUTIONS is offline
Skylights are my specialty. As a roofer and NOT an inspector. Over 20 years now in the trade
Ive seen them all, all types, all kinds, manufactured a few, repaired a few, fell through one or two....kidding..
Anyways....
Velux skylights are far the best on the market. Got that out of the way...
A cricket on a skylight. Maybe ? Never seen one. Either commercial or residential. However Ive not seen to many skylights over 30" Ive seen a few though and none of them ever had a cricket
It would make sense to add a cricket to the top side of the skylight greater than 30", but if the skylight is on a 4" curb? Your not going to gain to much of a slope to divert water away.
Curb mount skylights should be set on a 6" curb and NOT 4". Depending on location or climate conditions. Up North? Ice damns. Down South? Heavy tropical rains
Out west? Rains from every direction!
Water rushing down the roof would be less likely to get under 6"
There are a few tricks Ill share with you here in the forum
Weather Guard!!!
Weather Guard rain protector should be used around the entire skylight if you really want to make sure it wont leak. Wrapping the entire curb. 2.5 ft on the roof and .5 up the skylight curb. Corners wrapped just like you would wrap the metal flashings
With weather guard alone, your skylight is now watertight!
Roofers in general are very different from each other and installation practices from Washington DC to Florida and out to Texas are very different. Texas residential roofers being the worst Ive seen EVER!
If your skylight dont come with a pre-manufactured skylight kit Ie: Velux Flashing Kits
A roofer must make the curb flashings.
Pieces needed::
Top pan: Normally manufactured out of 24" .019 Aluminum or .24 galvanized coil stock (glavanize will rust over time) so Aluminum is preferred or copper. With copper you can sodder the corners
Step and counter flashings. Each side should ofcourse have step flashing per shingle or tile or...wood shake...slate...etc...
The bottom pan is nothing more than common apron flashings. Used to terminate a roof to the wall that is horizonal to the roof
With a 4" curb you should add a 1" return (philidelphia edge) to the top of the 4" side to stop water from rushing up under the curb mounted skylight.
A counter flashing should be used to cover the step flashings and yes, the bottom pan should be placed over the shingles and not under. However the reason some roofers do this over the metal method is to hide the flashings. Popular in northern states. I agree that this is a water trap and personally never install a shingle over the Apron flashings.
Ive got a detailed step by step on our website
Skylight Leaks | Skylight Repairs and Skylight Installations
Skylight repairs ?
Make sure you use Weather Guard!
  #20 (permalink)
Old 10-13-2008, 09:01 AM
Rick Hurst's Avatar
