Old 12-03-2007, 02:09 PM
Chimney flue
Old 12-03-2007, 06:42 PM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Re: Chimney flue
Jeff,
Technically it's a vent, not chimney. The flue is the space inside a flue liner. I don't recommend painting. Vents can rust from the inside out so paint won't do much. Eventually replacement will be necessary but for now it's ok.
As for the shingles. It's more a question of flashing, as in, where is it?
Eric Barker
Barrington, IL
Home inspection
Similar Threads
Chimney Flue / Insulation Shield Jeff Eastman Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 2 10-17-2007 06:23 PM
Pre-Fab chimney flue Martin lehman Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 1 09-05-2007 10:08 PM
Flue in return air. Eric Shuman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 1 08-04-2007 12:27 PM
WH gas Flue Vent K Robertson Plumbing System: Home Inspection and Commercial Inspection 14 05-20-2007 06:46 PM
Flue pipe wayne soper Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 10 04-21-2007 05:32 PM
vB.Sponsors
Ad Management by RedTyger
