Old 02-12-2008, 04:04 PM
Dennis R Dennis R is offline
Hip ridge vent
First time I've seen this. Looks like the set up is prone to trouble.
New construction (area underneath was finished.)
This is in the Boston area (cold snowy / wet / windy / ice dams etc.)
Any comments
Home inspection
Old 02-12-2008, 04:38 PM
Chad Fabry's Avatar
Chad Fabry Chad Fabry is online now
Re: Hip ridge vent
It's prone to leaking. It's designed as an exhaust vent and in its current configuration it will act as an intake. Not only that but it likely won't vent the attic space at all.
I'm not aware of any manufacturer of ridge vents that condone that installation.
Chad Fabry, Rochester, NY
StructureSmart Home Inspections, Inc.
www.structuresmart.com
Old 02-12-2008, 04:59 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
Re: Hip ridge vent
That looks like "ridge vent" and may not be "hip vent" The baffles are designed different so down hill water won't run in it. I have installed hip vent before but paid no mind as to who made it.
Here is what I'm talking about:
Trimline Products
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
Old 02-12-2008, 07:38 PM
Jerry McCarthy's Avatar
Re: Hip ridge vent
That's what I call disfunctional roof framing! What a place for a hip?
Construction Consultant
Similar Threads
ridge vent size wes owens Attic Areas: Home Inspection and Commercial Inspection 8 03-13-2008 09:30 AM
fastening at ridge Jerome W. Young Roofing System: Home Inspection and Commercial Inspection 5 01-12-2008 09:45 AM
ridge vents and hurricanes John Arnold Roofing System: Home Inspection and Commercial Inspection 8 08-02-2007 05:17 PM
Rafters larger than ridge Gregg Austensen Attic Areas: Home Inspection and Commercial Inspection 17 04-30-2007 10:41 PM
Rafter/ridge board Jeff Eastman Structural Components: Home Inspection and Commercial Inspection 7 04-18-2007 11:16 PM
vB.Sponsors
Ad Management by RedTyger
