Old 02-13-2008, 06:03 PM
Fritz Kelly Fritz Kelly is offline
Chimney flashing
There was no step flashing or counter flashing I could see. Besides the exposed nail heads, could this chimney be correctly flashed even though the flashing is not visible?
Old 02-13-2008, 08:38 PM
Richard Rushing's Avatar
Re: Chimney flashing
Is it flashed... looks like it on both the side (shown) and the front section.
Is is done right, probably not. The nail heads (for sure) should be sealed with a roofing sealant.
RR
Richard Rushing, HCRI
Duncanville, Tx.
Old 02-13-2008, 09:56 PM
Gunnar Alquist's Avatar
Shouldn't there be a weep screed to stop the stucco above the shingles?
What is the circumference of a moose?
Old 02-14-2008, 06:52 PM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Fritz,
My approach - if I don't see what I'm suppose to see, I write as such and suggest it be evaluated. I do the same when I find globs of caulk somewhere on the roof - it shouldn't be there if everything was done right.
No way would I even touch the question - "yea, but will it leak?"
Eric Barker
Barrington, IL
Old 02-15-2008, 05:42 AM
Quote:
Eric,
Don't be such a patsy, you know the answer to that question is always:
"Only when it rains."
  #6 (permalink)
Old 02-17-2008, 04:28 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
Would like to see the whole chimney but that doesn't cut it around here. Stucco to the shingles laves no room for replacement or repair. Also it appears the stucco installer cut the ear off on the corner.
Way we do it is we pre-flash the wall with counter held up off the roof 1" so the step flashing can be slid up under it. Then barriers go over the pre-flash. which has about 1/2" gap off the surface substrate. Siding installers go first then roofers when they are finished. Saves mess on the finished roof that way.
Heck with it, this picture will explain.................
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
Similar Threads
Flashing and sealant dan orourke Roofing System: Home Inspection and Commercial Inspection 4 11-19-2007 04:14 PM
vent flashing dan orourke Roofing System: Home Inspection and Commercial Inspection 0 07-20-2007 09:56 AM
Chimney stucco flashing on tile roofs Jeff Eastman Roofing System: Home Inspection and Commercial Inspection 1 07-13-2007 03:10 PM
Flashing at eave John Stephenson Roofing System: Home Inspection and Commercial Inspection 22 06-12-2007 08:58 AM
Chimney Flashing Warren Alderman Attic Areas: Home Inspection and Commercial Inspection 3 04-06-2007 08:43 AM
vB.Sponsors
Ad Management by RedTyger
