Old 03-16-2008, 07:39 AM
Reis Pearson Reis Pearson is offline
Flashing
I've run into this a couple of times and have been referring to it as improperly installed drip edge and wanted to get some feedback from the forum. I see major flaws in this design and wanted to know if this is a common practice or I just have the pleasure of running across the same roofer who hasn't had any problems with it??
Old 03-16-2008, 09:32 AM
Scott Patterson's Avatar
Scott Patterson Scott Patterson is online now
Re: Flashing
Yes it is wrong. The metal drip edge goes under the shingles.
Scott Patterson
Old 03-16-2008, 09:42 AM
Nick Ostrowski Nick Ostrowski is offline
Re: Flashing
Reis, that method of installation is common...........amongst people who don't know what they're doing.
Old 03-16-2008, 10:25 AM
Brandon Chew Brandon Chew is offline
Re: Flashing
There was probably an inspection done prior to yours and the inspector wrote up the lack of drip edge, so they "fixed" it.
Looks like a good way to rot out the fascia and roof decking. You don't get any rain in Seattle, do you?
What Nick said...
Old 03-16-2008, 11:07 AM
Michael Thomas's Avatar
Re: Flashing
http://www.nrca.net/rp/technical/files/4898.pdf
Similar Threads
Flashing and sealant dan orourke Roofing System: Home Inspection and Commercial Inspection 4 11-19-2007 05:14 PM
Vent flashing Jeff Eastman Roofing System: Home Inspection and Commercial Inspection 5 10-14-2007 08:26 PM
Unconventional flashing? Clay E White Roofing System: Home Inspection and Commercial Inspection 2 08-04-2007 08:48 PM
vent flashing dan orourke Roofing System: Home Inspection and Commercial Inspection 0 07-20-2007 10:56 AM
Chimney Flashing Warren Alderman Attic Areas: Home Inspection and Commercial Inspection 3 04-06-2007 09:43 AM
vB.Sponsors
Ad Management by RedTyger
