04-11-2008, 01:30 PM
Flue clearance
Does a water heater flue pipe require the same 3-2-10 rule same as firplaces. For the life of me I cant find my reference.
Jim
04-11-2008, 01:59 PM
Re: Flue clearance
Do not have code but if closer than 8 feet to wall vent must extend 2 feet above roof.
Dave
Re: Flue clearance
Jim, I'm not sure about that. But how close is that flue pipe to the adjacent roof surface? Is that type-B vent or single walled?
04-11-2008, 02:10 PM
Re: Flue clearance
That's single walled pipe. The pipe is almost touching the wood fascia. I have the one inch clearance from the roof sheathing but I dontThink I have one inch from the fascia. I'm also concerned about drafting properly.
Jim
04-11-2008, 02:16 PM
Re: Flue clearance
NFPA 54 12.7.2. Gas Vent Terminations.
A.........
B Gas vents that are over 12 inches in size or are located less than 8 ft. from a vertical wall or similar obstruction shall terminate not less than 2 ft. above the highest point where they pass through the roof and not less than 2 ft. above any portion of a building within 10 ft horizontally.
Dave
04-11-2008, 02:24 PM
Re: Flue clearance
Thanks david,
This site Rocks when I need it.
04-11-2008, 02:29 PM
Re: Flue clearance
Jim
Single Walled pipe clearance is 6 inches. B vent is 1 inch clearance from combustibles.
A.........
Also IRC. 2003 M1804.2.6
Billy J. Stephens HI Service
04-11-2008, 02:30 PM
Re: Flue clearance
Jim
That single wall should not be going through the attic. Needs to be type B or L.
Dave
04-11-2008, 03:00 PM
Re: Flue clearance
My bad, That is a type B flue, however it is less than 12 inches in diameter. Does the same clearance from horizontal objects apply?
Jim
04-11-2008, 03:06 PM
Re: Flue clearance
Jim
Yes..
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Toilet clearance |
Dan Harris |
4 |
04-02-2008 01:49 PM |
| Turbine Clearance from Flue(s)? |
Rick Hurst |
Attic Areas: Home Inspection and Commercial Inspection |
4 |
04-01-2008 09:32 AM |
| Clearance question |
Frank Bombardiere |
2 |
03-21-2008 07:43 PM |
| Service Clearance |
allen elliott |
3 |
03-20-2008 03:26 PM |
| Clearance for an air conditioner |
Kevin Luce |
7 |
08-20-2007 10:41 AM |
Ad Management by
RedTyger
